DrAmine
Just change only one set of parameters per run to be more consistent.
Coupled solver with pseudo transient is fine. Keep using small time scale at the beginning. You can even use the Coupled solver without pseudo-transient and tune the URF's /CFL.
Once again (my last comment on this) RPIS is generally used on coarse grid and intended for straight vertical pipes /tubes.
