You can do this using External Data.
First export the stresses and strains (I show this for a shell body, you wouldn't need thickness and different layer stresses if you are using a solid element model):
Import the exported CSV files using External Data and link them to the static analysis.
Once you haveĀ a structural analysis, you should see an option to import loads as shown below:
