sehallsanchez
Thank you for your help so far. I added into the command line the following:
"et,matid,226"
However I have the following errors in my Solver Information:
*****  ANSYS SOLVE    COMMAND  *****
 *** WARNING ***                         CP =       0.391   TIME= 1506
 There are no degrees of freedom defined.
 Element shape checking is currently inactive.  Issue SHPP,ON or
 SHPP,WARN to reactivate, if desired.
 *** ERROR ***                           CP =       0.391   TIME= 1506
 SOLID226 element 1 must have a nonzero KEYOPT(1) value.
Thank you.
