jj77
In workbench just use a nonlinear B-H curve fro the engineering data (you probably need to defin it yourself) and then set the polarization in the right direction  - you need to model the air ofcourse like in the tutorial.
If you want linear hard material (you can choose it in engineering data), then you need to know the coercive force and the residual induction of the magnet.
That is it
