Use an axis condition in place of symmetry (may not make any difference) and if you display contours don't select anything from the surface list (this avoids the mesh imprint you have).
Replot with node values off to see if the result is the same.  A blurry interface can mean poor convergence: also how big is the bubble relative to the domain.
