JamesWright
Command 3 was a "!sleep 5" to see if that would do anything. It didn't, so I just commented it out instead of going through all of the commands and subtracting one from their command number.
What I posted earlier is just a portion of the journal file used to run the simulation. The line length limits of the forum system would not allow me to post the script in full. Here are the other journal file commands:
/file/set-batch-options
; confirm file overwrite?
yes
; Exit on Error?
yes
; Hide Questions?
no
/server/start-server server_info.txt
/file/read-case p178L0260_S025_SBES.cas
/file/read-data 6587934_p178L0260_S025_SBES.dat
/solve/initialize/init-instantaneous-vel
; 24= Coupled
; /solve/set/p-v-coupling 24
/solve/set/under-relaxation/body-force 1
/solve/set/under-relaxation/mom 0.7
/solve/set/under-relaxation/turb-viscosity 0.8
/solve/set/under-relaxation/density 1
/solve/set/under-relaxation/omega 0.8
/solve/set/under-relaxation/k 0.8
/solve/set/under-relaxation/pressure 0.8
/solve/monitors/residual/convergence-criteria
.001
.0001
.0001
.0001
!date
report summary no
define/parameters/input-parameters/edit "TimeStepSize"
7e-5
{{{{VISUALIZATION PART FROM ABOVE}}}
/solve/dual-time-iterate 3
!date
/file/write-data 6634049_p178L0260_S025_SBES.dat
report summary no
;########### Parallel Timer Usage #####################
/parallel/timer/usage
;########## Time Statistics ###########################
report/system/time-stats
;########## System Statistics ###########################
;########## Processor Statistics ###########################
report/system/proc-stats
exit
yes
