simone01
Thanks for the reply.
Then I'll try again using watertight. The problem is that in update boundaries I detected the rotating zone of the impeller and the void of the impeller, but it did not detect all the volume outside the rotating zone. So would you suggest me to do two separate models (for the rotating zone and for the rest of the tank volume) and import them into fluent meshing for the MRF approach? Thank you
Best regards
