On further review, the initialization is what affects the convergence, not so much the mesh element quality. The following are both on Pressure Inlet and Outlet BCs. On the same good mesh, if I use Hybrid Initialization I get this convergence.
But if I use Standard Initialization, I get this convergence.
I will try negative velocity on the Outlet on another trial.
