You will be much better off once you get the midsurface finished. It will solve faster and with more accuracy.
You can create a plane and use the Move tool to drag it to the right location and then split the face with the plane.  You can also create a plane through the center of the pipe, draw some curves on that plane and Project those curves onto the midsurface.
