DrAmine
If not depicting a steady state behaviour you should run unsteady.
Generally boiling cases are run steady because they are expensive. Sometimes the trick is to use larger time scale to smooth out transient effect. Stop using automatic time scale and use a bit larger one. That helped me in my last 5 years boiling projects
