Georgiro1
I did it as I need it so now it is fine so thanks for your help! My general problem is to be able to find if I see the stars to change the dimension that it is not basically be changed - you cannot change it normally, so the point is how to find out to be changing the dimension in general. This looks as the most problematic way! Thanks for your ideas!
