Max Power
Hi jj77
Thanks for you input!
My question regarding the *GET command was, if anyone knows if there is an *GET command to get the solution time. In the help no solution option for the *GET command in relation to the solution time is mentioned. The example I gave is for the number of substeps. Something along the lines of *GET,someName,ACTIVE,,SET,TIME - but this is listed as an postprocessing option. I don't know if it will work during the solution.
Thanks for your suggestion with the *DO loop. I was trying to avoid a fixed time step solution, because of the added computational cost to my simulation, but if I don't find any other way this would be a solution.
