Delete all the lines and circles.  Start a Sketch, and under Options, check the Create Layout Curves checkbox. Draw a line that is 32.5 mm long at an angle of 55 degrees, then go back to the Select tool.
Start another sketch, but this time, without the Create Layout Curves option checked.  Draw a circle at the end of the line and type the diameter you need for the hole. Then go to 3D mode and use the Pull tool to make the hole.
