DrAmine
As I have couple of times said RPI does not like having fine near wall mesh. Make the mesh better finer off the wall and not at walls. I will always go for SST model for every engineering run.
Finer mesh would resolve more effects which might not be captured by the deployed techniques.
In case of unsteady I would start from results of steady run if well converged otherwise from scratch.
