Georgiro1
And now you can see these three holes, that one is white and the other two are a bit green as it can be seen and as well as I had to put the legth only of the depth of the material. And I had to create the depth of the hole on the basis of the length, otherwise it would not work at all. So I do not know what is this problem...
