jj77
You model wit 3d elements that is not used for frame structure and way to coarse mesh. First thing. The beam model would be to verify the solid model. The gravity was just to delete it, otherwise it is part of the total load. Finally think why you are doing this analysis. Often the codes will tell you have to assess a frame type of structure. So figure out why you are doing this analysis. Are you designing this look on relevant codes then.
