I'm guessing that you have a beam model, because beam elements have orientation nodes.
Linear beam elements have two nodes to define the line that the beam runs along.
Beam elements have a cross-section that has to be oriented around the beam.
An orientation node does that, but it can't if that node lies on the line between the other two nodes.  Move it off the line.
