Hello Edoardo,
No, the fillet would not be preserved if you choose to use midsurface. In fact, you have to delete them to perform the midsurface operation. You can do that in SpaceClaim under the Prepare tab.
Fillets the size of one wall thickness are not going to change the deformation significantly but if you want to study very large fillets, then you will need to keep the solid body.
