You set the flow based on the labelled boundary: in this case you have one setting for all 6 surfaces so use the total mass.  Turbulence conditions are based on the size of the openings and not the total area if there are several.
Set the model up, run a few iterations and then use the report tools to convince yourself what Fluent is doing.
