DrAmine
It is most efficient to switch off auto load balancing as it is too frequent for VOF-to-DPM (Uncheck box for MEsh Adaption). Instead of that you can execute the partitioning via calculation activities. You execute below commands every 50 time steps for example. Pleae check in Fluent and do not copy paste might be I am making an error here.
parallel/partition/method metis,
parallel/partition/reorder-partitions-to-architecture
parallel/partition/use-stored-partition
