  • Take a shaft, 9.6 mm diameter, 200 mm long.
  • Put a Fixed Support at both ends of the shaft.
  • Apply a bolt pretension of 25000 N.
  • Edit the Material to have Poisson's Ratio = 0 so the cross-sectional area doesn't change under load.
An almost exact match!
