pushkarkawale
I have a problem in ANSYS Workbench  Solution. I have made an analysis setting as Store Output Results at last point only to solve the issue related with disk space. Now in solution, it shows following error message.
Text: "An unknown error occurred during solution.  Check the Solver Output on the Solution Information object for possible causes."
 *** ERROR ***                           CP =   29929.479   TIME= 21:420
 The program is unable to open file file.DSP.  If the suggestions in the
 associated error messages immediately preceding and/or following this
 error message do not help resolve the file issue, please send the data
 leading to this operation to your technical support provider, along
 with the I/O error code of 30 and the system error code of 32, for
 help in determining the possible reasons as to why this file could not
 be opened.
 NUMBER OF WARNING MESSAGES ENCOUNTERED=          1
 NUMBER OF ERROR   MESSAGES ENCOUNTERED=          1
 ***** PROBLEM TERMINATED BY INDICATED ERROR(S) OR BY END OF INPUT DATA *****
Help me please for this problem.
