NTAKMAT
I need also a help on how to insert spring between two bodies and body to ground in ansys workbench by using apdl command.
spring have the following properties:
Stiffness: 34000 N/mm
damping: 12.5 N.s/mm
Length: 12 mm (body to body) and -350 mm (body to ground)
