theodoreyang
Hi DavidW,
Here is the APDL code. Thanks.
/prep7
/com *** Geometry
length = 10.0           ! model centered at (0,0,0)
width = 10.0            ! geometry for each block
thickness = 10.0
xnum = 15    ! quantity of element on x
ynum = 15    ! quantity of element on y
znum = 20     ! quantity of element on z
et,1,185    ! element type
/com *** Material Properties *********************************
mp,ex,1,   2000.0
mp,nuxy,1, 0.3
mp,alpx,1, 52e-6
/com *** Model ***** centered at (0,0,0)**********************
/com *** Corner made by 7 small blocks
BLOCK, 0, length, 0, width, 0, -thickness/4    ! x1,x2,y1,y2,z1,z2
BLOCK, 0, -length, 0, width, 0, -thickness/4
BLOCK, 0, -length, 0, -width, 0, -thickness/4
BLOCK, 0, length, 0, -width, 0, -thickness/4
BLOCK, 0, length, 0, width, 0, thickness
BLOCK, 0, -length, 0, width, 0, thickness
BLOCK, 0, length, 0, -width, 0, thickness
vglue,all
/com ***mesh
type,1
mat,1
x_size = length/xnum
y_size = width/ynum
z_size = thickness/znum
lesize, 7, x_size   ! element size on x
lesize, 8, y_size   ! element size on y
lesize, 9, z_size   ! element size on z
lesize, 97, x_size   ! element size on x
lesize, 92, y_size   ! element size on y
lesize, 85, z_size   ! element size on z
vmesh,all
/com *************************************************************
/com
/com                    INITIAL CRACK DATA
/com
/com ***define crack position
x0 = 0
y0 = 0
z0 = z_size/2
xc = x_size/2
yc = y_size/2
zc = z_size/2
/com ***define enrichment identification***********************
esel,s,cent,x,-length*1,length*0.5
esel,r,cent,y,-width*1,width*0.5
esel,r,cent,z,-thickness/4,thickness/4
cm,testcmp_1,elem                    ! name the element set for xfenrich
allsel
xfenrich,ENRICH_1,testcmp_1     ! define the method: phantom node (default) or SIF
/com ***loop for crack level set identification***********************
esel,s,cent,x,x0-x_size*1,xc+x_size*0.499
esel,r,cent,y,y0-y_size*1,yc+y_size*0.499
esel,r,cent,z,z0,zc+z_size*0.499
cm, cenelem, elem    ! name the element set for vertical crack elements
nelem = 1000
iel = 0
Phi = 0.0
Psi = 0.0
*do, i, 1, nelem, 1
 iel = elnext(iel)
 *if, iel, ne, 0, then
  *do, j, 1, 8, 1
    nd = nelem(iel,j)
    Phi = nz(nd) - zc
    xfdata, ENRICH_1, LSM, iel, nd, Phi
  *enddo
 *endif
*enddo
cm, crktipelem, elem
allsel,all
/com ******** Boundary conditions *********************
nsel,s,loc,x,0
nsel,r,loc,y,0,-width
nsel,r,loc,z,0,thickness
d,all,all,0
nsel,s,loc,x,0,-length
nsel,r,loc,y,0
d,all,all,0
nsel,r,loc,z,0
d,all,all,0
nsel,s,loc,x,-length-x_size/2,-length+x_size/2
dsym,symm,x,0
nsel,s,loc,y,-width-y_size/2,-width+y_size/2
dsym,symm,y,0
allsel
/com ******** Temperature load *********************
Tref,150
BF,ALL,TEMP,25
/SOLU
autots,on
time, 1.0                  ! --- time
deltim,0.05,0.05,0.05
outres,all,all
tb,cgcr,1,,,STTMAX  ! crack growth criterion, max circon stress
tbdata,1,3
tb,cgcr,1,,,RLIN    ! rigid linear law
tbdata,1,0.04,,,0.05
CINT, NEW,1
CINT, CXFE,crktipelem
CINT, TYPE,STTMAX
CINT, RSWEEP,181,-60,60
CINT, NORM, 0, 3
CGROW,NEW,1
CGROW,CID,1
CGROW,METHOD,XFEM
CGROW,FCOPTION,MTAB,1
SOLVE
Save
/POST1
SET,LAST
