Sandeep Medikonda
If you know what to put in the sub file, then please refer to section 4.5 of the ANSYS Parametric Design Language Guide which discusses an example:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v192/ans_apdl/apdlsuper.html
It looks like you are specifying the input in the rowinfo matrix.
Above is true only if you know what to put in the sub file. What is your scenario and what version are you using? You should be able to create a CMS superelement within Mechanical (which is basically the sub file)
