tsiriaks
Something on this systems is preventing the Ansys.ACT.Browser.exe process to run.
Are you using VPN ?
If not, I'd suspect your Avast security causing the issue. The Ansys.ACT.Browser.exe process 'uses' web browser in the backend, so you may need to disable Avast Secure Browser as well. Or if possible, I would say uninstall it for a test and see if it makes any differences. If so, reinstall Avast and find which Avast tool is blocking it.
Thanks,
Win
