August 28, 2022 at 4:31 pm
javat33489
SubscriberWhen setting the rotation speed in LS-PREPOST. Please tell me how to convert rad/s to mm? Those. the speed will be determined by the movement of the drill a distance around its axis.
August 29, 2022 at 4:12 pm
Reno Genest
Ansys EmployeeHello,
The tangenntial speed is v = omega*radius(mm). You can use the radius of the drill in mm and the tangential speed you want to calculate the rotation speed (omega = v/r). Here is more information:
https://www.khanacademy.org/science/in-in-class11th-physics/in-in-class11th-physics-motion-in-a-plane/uniform-circular-motion-introduction/a/circular-motion-basics-ap1
Reno.
Reno.
August 29, 2022 at 6:11 pm
javat33489
SubscriberThank you!
August 30, 2022 at 6:39 pm
javat33489
SubscriberBut I don't need speed, I need movement
August 30, 2022 at 6:50 pm
Reno Genest
Ansys EmployeeWith the speed you can calculation displacement. Assuming a constant speed, you can calculate a displacement based on the time. For example, if you need a displacement of 10 mm in 1 second, then the constant speed will be 10 mm/s. You can then calculate the rotation speed using the equation above.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
2644
2110
1335
1112
461
