April 17, 2022 at 9:49 am
HaoHAO
Subscriber我希望将一个仿真在某个方向(x方向)输出光作为另一个仿真的激励源,光场分布用DFT记录了下来,光谱用时间监视器记录了下来,DFT和时间监视器都是linear Y的,想问一下怎么操作才能将这些数据导入import source里(或者还缺什么数据)
April 19, 2022 at 3:23 pmGuilin Sun
Ansys Employee以后请发到中文论坛,不要重复发贴。Viewing 1 reply thread- You must be logged in to reply to this topic.
- Error on Lumerical device
2706
2146
1357
1144
462
