October 30, 2023 at 5:23 pm
Kenneth Ekpo
SubscriberI am now using 2023 R2. After updating my software I tried to run an earlier archive which I have been using as a baseline with no convergence issues for my previous version.
I have not been successful in making my model converge. I have been probing this and I heavily suspect the problem might be from my frictional contacts. I am running a model with a lot of sheet metal parts hence I have a lot of frictional surfaces. Prior to this i had left them as frictionless but this gave me convergence issues especially with large defelctions turned on.
Do you think I should surpress all my frictional contacts. is there a good substiture for this. In my 2022 R2 I had no convergence issues.
On this s9lver i m also having scoping issues. Anytime i try to update my model on space claim and re import geometry other parts start to loose scoping or simply become unsurpressed and cause convergence issues. is there also a good solution to this as well or am i missing a setting.
October 31, 2023 at 6:04 am
Akshay Maniyar
Ansys EmployeeHi Kenneth,
I do not see any details in your post. Did you mean to post something else? Let me know if you have some issues while posting your query. I will be happy to help you.
Akshay maniyar
October 31, 2023 at 12:37 pm
Kenneth Ekpo
SubscriberThanks Akshay that was an error on my part. I have updated the question now.
- Defining rigid body and contact
- A solver pivot warning or error has been detected
8786
4658
3151
1678
1468
