May 13, 2022 at 1:04 pm
piknockyou
SubscriberHi.
Which setup is preferable for Ansys Mechanical running on 4 cores?
Which will result in better performance / faster solution?
8X16 GB RAM or 4x32 GB RAM?
And why?
Mainboard DELL X8DXD with Intel Xeon W-2125 4 Core CPU.
May 18, 2022 at 8:01 pmHunter Wang
Ansys EmployeeRefer https://www.dell.com/support/manuals/en-us/precision-5820-workstation/precision_5820_om_pub/memory-specifications?guid=guid-5ee14007-db24-4d37-aecb-34dea3370abb&lang=en-us
and https://www.dell.com/support/manuals/en-us/precision-5820-workstation/precision_5820_om_pub/memory-configuration?guid=guid-ce1561c8-88a9-45e3-bc3b-762cbb37e073&lang=en-us
Both 8X16GB and 4X32 GB should operate at DDR4-2666 MHz for W-2125, should be no difference for memory bandwidth and MAPDL solver performance.
I prefer 4x32 GB RAM. 3 reasons:
almost same price to 8X16GB
1DPC (dimm per channel) configuration usually doesn't downgrade speed, 2DPC may do.
4 DIMMs left for future upgrade
May 19, 2022 at 9:11 ampiknockyou
SubscriberThank you!
May 19, 2022 at 2:09 pmpiknockyou
Subscriber,please read this:
http://simutechgroup.com/wp-content/uploads/2020/09/maximizing-memory-performance-for-ansys-simulations-2018.pdf
Bottom line: Utilise all memory channels!
Correct me if I am wrong, but in general it seems 8x16GB is better for performance over 4x32GB, isn't it?
Edit: Yes, but only if the mainboard had 8 memory channels. In the case of the mainboard DELL X8DXD following is stated: "4 channel memory up to 256 GB 2666 MHz DDR4 ECC memory with single CPUs on Xeon W Sky Lake Series CPUs".
https://www.dell.com/support/manuals/de-de/precision-5820-workstation/precision_5820_om_pub/memory-specifications?guid=guid-5ee14007-db24-4d37-aecb-34dea3370abb&lang=en-us
Since the Mainboard has only 4 channels, one would only need to make sure, that all of the 4 channels are utilised, either by 8x16GB ignoring any order or 4x32GB necessarily considering the order in the following way:
So thanks again for the links! : )
Viewing 3 reply threads- The topic ‘8X16 GB RAM VS 4×32 GB RAM’ is closed to new replies.
Trending discussions- Licensing – Request name does not exist in the licensing pool
- 2022 R1 Ansys Mechanical APDL: QXcbConnection: Failed to initialize XRandr
- error “ansyslmd: Cannot connect to license server system. (-15,10032)
- The analysis systems in Workbench are missing
- Student license renewal
- Mechanical APDL Launcher Options
- how to open files created from newer version by using the older version of ansys
- Problems using 2022/R2
- Ansys Helic Tools Installation Issue: Missing Helic_PDK directory
- Results Probe in ANSYS Workbench
Top Contributors-
8808
4658
3153
1680
1470
