February 23, 2022 at 8:02 am
HeSu
SubscriberFebruary 23, 2022 at 4:44 pmGuilin Sun
Ansys Employee后处理是为了制造还是准备插图?如果为了制造,我们一般输出为GDS,参见 GDS pattern extraction for inverse designed devices using contours method
除此之外,目前没有其它方法,你可能需要在其它软件里面再画了。
February 24, 2022 at 7:45 amHeSu
Subscriber谢谢孙老师,我是为了制造。看了下您给的这个例子,它是对模型的监视器提取一些数据,不是对结构组进行操作的。我想把几何结构组输出为GDS,有办法吗,谢谢。
February 24, 2022 at 4:46 pmFebruary 25, 2022 at 7:26 amHeSu
Subscriber非常感谢孙老师,我学习一下。
February 25, 2022 at 9:31 amHeSu
SubscriberFebruary 26, 2022 at 5:10 pmViewing 6 reply threads- You must be logged in to reply to this topic.
- Error on Lumerical device
2524
2066
1279
1096
457
