May 27, 2022 at 12:43 pm
White_Lee
Subscriber老师您好,请问为什么石墨烯的化学势无法设置为负数?当仿真双层石墨烯结构时,两层石墨烯分别加电压大小相同、正负相反的电压,这时两层石墨烯的化学势(即费米能级)应该分别是一正一负、数值相同的。
May 27, 2022 at 5:41 pm
Guilin Sun
Ansys Employee我估计这个是一个选择参考零点的问题。相反电压只是向两个方向改变势能,实际的势能可能并不是负的,是相对参考点才成为负数的。
Wiki上讲:
Fermi level referencing and the location of zero Fermi level
Much like the choice of origin in a coordinate system, the zero point of energy can be defined arbitrarily. Observable phenomena only depend on energy differences. When comparing distinct bodies, however, it is important that they all be consistent in their choice of the location of zero energy, or else nonsensical results will be obtained. It can therefore be helpful to explicitly name a common point to ensure that different components are in agreement. On the other hand, if a reference point is inherently ambiguous (such as "the vacuum", see below) it will instead cause more problems.
A practical and well-justified choice of common point is a bulky, physical conductor, such as the electrical ground or earth. Such a conductor can be considered to be in a good thermodynamic equilibrium and so its µ is well defined. It provides a reservoir of charge, so that large numbers of electrons may be added or removed without incurring charging effects. It also has the advantage of being accessible, so that the Fermi level of any other object can be measured simply with a voltmeter. https://en.wikipedia.org/wiki/Fermi_level
如此以来,很可能不同文献所指的势能实际有可能不同。
如果你认为必须用负的势能,请提出新功能请求: 为可能的新功能投票和提交新功能需求
- 询问关于FDTD和matlab软件的互联问题 ——appopen
- Ansys Insight: FDTD 和 varFDTD 常见的发散原因以及处理
- Ansys Insight: FDTD 如何设置圆偏振光
- 如何仿真一维光子晶体能带?
- 老师,您好。FDTD中simulation bandidth和source中wavelength区别在哪里,仿真根据哪个进行?
- Ansys Insight: 几个简单实用的脚本Script命令:用于结果分析
- Ansys Insight: 透射率反射率大于1,或者透射率反射率之和大于1的原因与解决方案–综合贴
- Ansys Insight: FDTD 初学者: 平面波和全场散射场tfsf光源有什么区别
- 左旋圆偏振光透过超表面后,获得的右旋圆偏振光能量比入射的左旋圆偏振光能量还要大?
- Ansys Insight: script中的数据类型和数据格式 Dataset
3744
2573
1809
1236
594
