Ansys Products
Ansys Products
A current stk license could not be found.
    • itdesk
      Dear Support,
      I have installed version 12.5
      I have installed the latest versions of both the client and ansys license server. I have also ensured the license is up to date. I do have a green check mark from the client side. I do run all installs as Admin.
      Thank you,
      Robert
      416 319 8383
      milver73@yorku.ca
    • Matt Madore
      I've reached out directly on this issue.
    • Matt Madore
      For reference, starting with 2021R1 the applications must communicate through ansyslmd and lmgrd, where past releases used lmgrd and the ansysli_server process on 2325.
      In this case all your other products worked because they were running versions 2020R2, using just the lmgrd and ansysli_server ports which were already open on the firewall. So adding the ansyslmd process to the Windows firewall resolved the issue.
      Thanks
      Matt
