A problem for dynamic adapt mesh
    • hmily
      When I import case and date of some time step,which was cacullated before.After the cacullation beginning ,the mesh will be refine to much more than the degree of the refine criteria。I think it is becuase of FLUENT regard the mesh refined in the case as initial mesh to refine again .But I don't know how to solve this problem,therefore I want to find an answer here .thanks!
      Are you reading in a .cas.gz or a .cas.h5 file?
    • hmily
    • hmily
      Thinks,I am reading in a .cas file wit Fluent 2021 R1 not a .case.h5 file.
      OK, that doesn't retain any adaption data so can mean you get additional adaption over not pausing the run. The newer h5 (HDF) format retains registers and adaption levels so should avoid this issue.
    • hmily
      YES,I will have a try.
Viewing 5 reply threads
