Preprocessing
Preprocessing
“A problem has occurred while accessing the attached Geometry”
    • maimrtza
      I got this message when I imported the geometry to mesh :“A problem has occurred while accessing the attached Geometry. You may need to modify and re-import and upstream data”. Some parts of my model body were missing but when I checked on Design Modeler, nothing is wrong. Meshing error
      Alternatively, does anyone know how to convert and igs file to Catia V5 file? When I opened an igs file on Catia V5, some surfaces were marked as error. Thank you!
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
      also i saw some post on this geometry about creating solids from surfaces where you have got some reply.
      please follow one post for one question.
      design modeler can import step and iges in student version.
      Keyur
    • maimrtza
      failed mesh
      Hope you can see it here.
Viewing 3 reply threads
