a question about beam element stiffness matrix
    • 567
      I've exported the stiffness matrix of a beam element. but the value is not equal to my calculation. and I've calculated the size of the beam element based on the value of stiffness matrix. the result is not equal to my set.
      this is the apdl command line:
      finish
      /clear
      /PREP7
      /NUMBER,-1
      /VIEW,1,1,1,1
      /ANG,1
      ET,1,BEAM188 ! BEAM
      SECTYPE,1,BEAM,CSOLID
      SECDATA,0.003,120
      MP,EX ,1,2.07E11
      MP,PRXY,1,0.3
      MP,DENS,1,7800
      N,1,0,0,0
      N,2,0.1,0,0
      TYPE,1
      MAT,1
      SECNUM,1
      E,1,2
      D,1,ALL
      /SOLU
      ANTYPE,2
      MODOPT,LANB,10
      MXPAND,10,,,0
      SOLVE
      this is the result:
    • Erik Kostson
      The stiffness matrix you are showing in the image above (e.g., 12*E*I/L^3) is for an Euler beam theory.
      The old legacy Euler-Bernoulli beam is called BEAM4 - so you would need to use this element in order to compare to the above equation.
      Hope this helps
      All the best
      Erik
    • 567
      this is it, but There's too much deviation. I think this is not correct, thanks for your reply
    • 567
Viewing 3 reply threads
