November 12, 2018 at 11:15 am
November 12, 2018 at 11:21 am
seeta gunti
Ansys EmployeeHello,
If you want to model the compressible flows, you need to specify the density as Ideal gas.
If you specify density is a function of temperature, density varies wrt to temperature only but not with pressure. In this case, pressure remains constant almost.
Seeta
November 12, 2018 at 12:12 pm
DrAmine
Ansys EmployeeJust in addition to Seeta: If you want to model compressible flow the density has to be a function of pressure. So either you follow what Seeta suggested: Ideal Gas or Real Gas or providing a function for density user defined real gas model.Compressible flow are flows with significant change in density. Generally one rely on the Mach number to judge whether compressibility effects are relevant or not. But even at low Mach numbers for some applications compressibility or at least temperature dependency of the density is very important!
2656
2120
1345
1118
461
