November 29, 2022 at 10:24 am
Zhang Huiyu
SubscriberMy example is a surface plasmon metamaterial absorber. During my simulation, if the simulation time is set slightly larger than the propagation distance /c*index, the simulation results are normal. However, when the time is increased to a larger amount, the numerical changes of the reflectance and refractive index will be very large, like the situation of noise. At this time, R+T> will appear at some wavelengths. 1 case. I found some information that the simulation time is too short, the result is not accurate, it needs to increase the simulation time, if the simulation time is too long, will it have an impact?
November 29, 2022 at 9:26 pm
Guilin Sun
Ansys EmployeeI am not sure how the refractive index also changes with simulation time.
In general, you will need the simulation run long enough to reach the preset autoshutoff min, which by fault is 1e-5. If the result is suspicious you may need to reduce it further. Please refer this post
Ansys Insight: 透射率反射率大于1,或者透射率反射率之和大于1的原因与解决方案–综合贴
R+T >1 can be due to a number of reasons:
- Error on Lumerical device
2726
2148
1359
1150
462
