a question about porous
    • stao li
       A chamber connecting some tubes with a inlet on one side,how is possible the fluid share a same velocity in everytube when adding the porous?it is wild
      If you check the mass flow on each channel are they the same? If you plot static pressure on the same plane I suspect it'll help you understand.
      • stao li
        The value of velocity and other parameters should relatived to the position. i checked the mass flow  and static pressure , and they are the same. it confused me
      Why would velocity vary with position? With a manifold & porous resistance in each channel why are you not expecting the above?
