September 4, 2019 at 2:26 am
September 4, 2019 at 5:35 pm
SubscriberThere is more than one way to obtain this information, here is one way.
Insert a fixed joint in the Connection folder to connect the cylinder with the fixed tip of the gripper. Make sure the joint coordinate system is at the center of the cylinder. You can do that by picking the two ends of the cylinder as the Reference objects of the Fixed Joint, then pick the face of the fixed gripper as the Mobile side of the Fixed joint. This assumes the cylinder and fixed finger of the gripper are separate bodies and there is no bonded contact between them.
Define a Frictional Contact between the cylinder and the moving face of the gripper.
Insert a Joint Probe into the Solution and you can request the Total Force going through the Fixed Joint.
What are you using to move the moveable finger? A force or a displacement? Where is that applied?
2120
1347
1118
461
