October 25, 2018 at 4:24 am
ruggerostark
Subscriberhello everyone
a triple loft
three circles on three parallel planes
I do the loft
I have to change the diameter of the central circle
with any parametric, in this case I used zw3d , file gif ,
I go back to the sketch I modify the diameter and it's over
spaceclaim the sketches eats them when I do the loft
how do you change the diameter of the central circle?
regards
October 25, 2018 at 4:36 am
Keyur Kanade
Ansys EmployeeHello,
As ANSYS employee, we can not download attachments. Can you please insert image and explain your problem in detail.
Keyur
October 25, 2018 at 4:47 am
October 25, 2018 at 5:27 am
October 25, 2018 at 5:28 am
October 25, 2018 at 5:30 am
Keyur Kanade
Ansys EmployeeHi,
On another note, if you want to do it in SpaceClaim then it may be possible through scripting.
Keyur
October 25, 2018 at 9:20 am
October 25, 2018 at 10:41 am
Keyur Kanade
Ansys EmployeeGreat!
Can mark this as 'Is Solution' so that others on forum can benefit from it.
Thanks!
Keyur
October 25, 2018 at 2:50 pm
FrankD
Ansys EmployeeDesign Modeler allows you to modify the original curves that occur before the Blend.
As SpaceClaim has no history, the way to achieve this, as ruggerostark points out (in Italian), is with the Tweak Face tool. Inside there are Edit Method choices, and the one you want is Blend Curves. This reverse-engineers the minimum set of curves required to re-define the selected face, and allows for Control Curve, Move, and Scaling to be done to any selected definition curve. The neat part about it is that it works on faces in general, not just faces that were originally created as Blends. It effectively Edits the selected Face as if it had been blended. This is patented and fairly advanced SpaceClaim functionality, albeit somewhat buried in the UI.
F
October 25, 2018 at 10:33 pm
October 26, 2018 at 3:50 am
Keyur Kanade
Ansys EmployeeHi,
Sorry about that. I did know that DM can easily do it. I did not know SpaceClaim Tweak tool can do it. I also learned from you.
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2524
2066
1285
1096
459
