August 7, 2018 at 8:32 pm
Vladimir
SubscriberI am trying to calculate flow of steam valve in Ansys CFX. Boundary conditions : at inlet - massflow rate and temperature of steam, at outlet - averaged pressure of steam; wall for all other faces ;relative pressure - 0.
After calculation i have that steam does not pass throught outlet. In solution log i have:"
****** Notice ****** |
" | A wall has been placed at portion(s) of an OUTLET |
| boundary condition (at 100.0% of the faces, 100.0% of the area) |
| to prevent fluid from flowing into the domain. |
| The boundary condition name is: Outlet. |
| The fluid name is: Steam1. |
| If this situation persists, consider switching |
| to an Opening type boundary condition instead. "
How could this happen ?
August 8, 2018 at 2:46 am
Surya Deb
Ansys EmployeeHi Vladimir,
This happens when there are re-circulation zones near the outlet. The vortices or re-circulations crossing an outlet will cause the CFX Solver to close part of the outlet with walls to avoid fluid from coming in from an outlet.
A couple of remedies for this issue are:
1.) Extending the outlet further downstream or away from the regions of re-circulations.
2.) Using an Opening boundary condition .
I hope these will help.
Surya
August 8, 2018 at 8:26 pm
Vladimir
Hi Vladimir,
Surya
Surya, thanks you very much for your answer. I have find the solve of this problem on ResearchGate site. Apparently, error cause was initialization of the flow domain in an unbalanced thermodynamical state. If you interested you can look the discussion by this link:
https://www.researchgate.net/post/Why_Ansys_CFX_placed_a_wall_at_outlet
2656
2120
1347
1118
461
