Ansys Free Student Software
Abnormal Exit Error
    • GabrielL
      Hi all,
      I have been using Workbench 19.2 (Fluent) for a while and I have recently repetitively experienced situations in which Fluent automatically shuts down occasionally when it was running, showing error messages "Abnormal exit!". What are the possible causes and remedy to this problem?
      Thanks very much!
    • tsiriaks
      Hi GabrielL ,
      This symptom is definitely not common.
      Does this always/usually happen when you are doing certain tasks in the software (e.g., meshing, solving, rotating models, etc.) ?
      There might be some information in your Windows Event Viewer. You can open that up -> Custom Views -> Administrative Events , then see if there is any event related to Fluent crashing logged in here. Another location you can check is -> Windows Logs -> Application
      Also, can you try using stand-alone Fluent (not via Workbench) , do you experience the same issue ?
      Thanks,
      Win
    • GabrielL
      Thank you for your reply.
      Usually, this error happens during the solving process occasionally only. Otherwise, Ansys worked normally in other aspects.
      I have checked the events log and revealed the followings:
          1000
          2
          100
          0x80000000000000
          52675
          Application
          DESKTOP-KJC3FR8
          fl1920.exe
          0.0.0.0
          5b6b2ac7
          ABQSMARfmInterface.dll
          0.0.0.0
          53d35deb
          c0000005
          00000000000158d2
          3d4c
          01d4a836d11caa91
          C:PROGRA~1ANSYSI~1ANSYSS~1v192fluentfluent19.2.0win643ddp_hostfl1920.exe
          C:PROGRA~1ANSYSI~1ANSYSS~1v192fluentfluent19.2.0vkiwin64libodb6145ABQSMARfmInterface.dll
          2364f447-1042-4b33-9480-9f1477b6c764
      There was also a warning related to "Resource-Exhaustion-Detector".
      Thank you very much for your help!
    • tsiriaks
      I've never seen the issue with this dll. If it only happens occasionally, it could be specific to certain projects or certain things that those projects are using during the solve.
      Please confirm this question, it could give some crucial information
      "Also, can you try using stand-alone Fluent (not via Workbench) , do you experience the same issue ?"
      Thanks,
      Win
    • tsiriaks
      I just got some information about that dll
      It seems to be related to Abaqus. You might be missing some prerequisites.
      Are you doing Fluid-Structure Interaction (FSI) simulation ?
      Also, verify that this dll exists under that v192 folder  .......v192fluentfluent19.2.0vkiwin64libodb6145ABQSMARfmInterface.dll
      Thanks,
      Win
    • GabrielL
      Yes I'm doing Fluid-structure Interaction problems. They include simulation of a ship on water using VOF model and also wind flow around a building using LES.
      I have checked and verified that the dll .......v192fluentfluent19.2.0vkiwin64libodb6145ABQSMARfmInterface.dll exists in the v192 folder.
      I have also tried Fluent standalone (without Workbench). It seems similar problems occurred.
      In fact, I have also experienced other problems when opening Fluent via workbench in which it shows "Fluent failed to validate the connection", usually when I update the upstream mesh file. These are usually solved by reloading Fluent but I'm not sure if this symptom has any further implications.
      Thank you once again for your help!
    • Karthik R
      Administrator
      Are you seeing this issue as soon as you open Fluent or do you see this issue when you are attempting to run a model (in the middle of your simulation)?
      If this is happening in the middle of your simulation, could you please do the following?
      • Open Fluent in Standalone mode.
      • Before you read your case and data files, please go to File -> Write -> Start transcript
      • Now run your model and see if the issue repeats. If there is an abnormal exit, Fluent should have written out the error message / issue in the transcript file.
      Could you please share a screenshot of the error here with us?
      Regarding your other error "Fluent failed to validate the connection" - could you please share a screenshot of your workbench?
      Thank you.
      Best Regards,
      Karthik
    • Anupama
      Hello everyone
      I'm facing same issue of 'Abnormal exit'. Can anyone plz help me to resolve?
    • tsiriaks
      Please open a new thread and include the requested information above.
      Thanks,
      Win
Viewing 8 reply threads
