December 14, 2022 at 3:31 pm
December 14, 2022 at 5:23 pm
Guilin Sun
Ansys EmployeeWith very little information, it is hard to say what is the cause. Please refer the example: https://optics.ansys.com/hc/en-us/articles/1500006203341-GDSII-Export-Automation
I would suggest to test the case with fewer geometry and see if it works. GDSII supports limited number of points, depending on the version. Here are a few posts that might be helpful:
Lumerical FDTD gds export vertices limit
- Error on Lumerical device
2524
2066
1279
1096
457
