February 24, 2022 at 1:13 am
zuoyandaoying
SubscriberFebruary 24, 2022 at 9:55 pmGuilin Sun
Ansys EmployeeSince this is FDTD simulation, you can use a frequency-domain monitor above and below, then do a farfield projection: Understanding field polarization in far field projections
Please note that 2D FDTD means the 3rd dimension is infinite. But from your screenshot the 3rd dimension is very limited. so the actually true result of the device may be different from your 2d result.
February 25, 2022 at 1:56 amzuoyandaoying
SubscriberThanks for your solution. Could I ask again´╝ƒIt is 2D simulation because this structure is very small. And I am not sure about your "Please note that 2D FDTD means the 3rd dimension is infinite. But from your screenshot, the 3rd dimension is very limited "
If you can explain for me, I am very thankful for you.
February 25, 2022 at 5:37 pmGuilin Sun
Ansys EmployeePlease refer this article: Finite Difference Time Domain (FDTD) solver introduction
2D simulation has suppressed some field components whereas in your waveguide, the 3rd dimension, eg, zspan of the waveguide is about micron scale, which means it will confine the EM fields, and thus will have the full 6 EM fields. You can also check the mode profile: in 2D simulation the field intensity is a line, it means it duplicates infinitely in the 3rd dimension. In 3D, the E intensity of the mode will gradually decrease.
2D simulation means at any location of z, the device is the same. Obviously your device is not the case. right?
- Error on Lumerical device
2508
2064
1277
1088
456
