September 9, 2022 at 1:51 am
2212296
SubscriberHi guys, I'm drawing a structure with more elements, the structure is divided into parts and loaded into the simulation environment one by one. However, I ran into a tricky problem. After I loaded the first part, when loading the second part, I found that the already loaded first part has been automatically deleted. The result is that only the last part of the structure appears in the simulation. This is too bad. Hope you can help me solve this problem.
September 9, 2022 at 1:55 am
September 9, 2022 at 2:04 am
2212296
SubscriberAfter the program run, only the structures loaded by 'afilm_3.fsp' exist, and 'afilm_1.fsp' and 'afilm_2.fsp' have been deleted. How can I keep afilm_1.fsp', 'afilm_2.fsp', and 'afilm_3.fsp' present at the same time?
September 9, 2022 at 5:43 pm
Guilin Sun
Ansys EmployeeYou are right that one GUI can only hold one file. You want to simulate them sequntially, right? if so, please use
addjob
runjobs
please refer
https://optics.ansys.com/hc/en-us/articles/360034410714-addjob-Script-command
https://optics.ansys.com/hc/en-us/articles/360034931373-runjobs-Script-command
this way it will run all the loadded files provided you add them into the simulation queque.
September 10, 2022 at 1:45 am
2212296
SubscriberHi, I took your suggestion. Yes, it works in some ways. This seems to emulate each individual fsp file, and there is no connection between them. However, my job is to do a simulation of a large structure. The structure was so big that I had to split it into several parts (several fsp files). I hope that after running several fsp files, they coexist and combine into this big structure.
September 10, 2022 at 2:19 am
2212296
SubscriberAlso, I'm trying to write small structs into the 'object library' so that I can export small structs to compose a big struct. But that doesn't seem to be allowed.
I don't know if my thoughts are clearly expressed. Hope to get your help. thank you very much.
September 12, 2022 at 12:20 am
2212296
SubscriberI'm very sorry to bother you again. Although I've been trying to figure this out these days. However, it didn't work. Hope you can give me some advice. Sincerely.
September 12, 2022 at 2:16 pm
Guilin Sun
Ansys EmployeeOne large device in general can only be deviced into section along the propagation direction, eg, cascading. please refer this exmple: https://optics.ansys.com/hc/en-us/articles/360034383034-Using-monitor-data-to-define-the-spatial-field-profile-of-a-source-in-FDTD
Doing so we assume there is no cavity effect by the two parts.
One large device can only be simulated by distributed parallel simulation: https://optics.ansys.com/hc/en-us/articles/360026321353-Distributed-computing
in one file.
September 14, 2022 at 1:01 am
2212296
SubscriberThank you very much for your reply, your work is very meaningful.
- Error on Lumerical device
2722
2146
1357
1150
462
