About mesh, please help me!
    • hakan
      Hello guys,
      I am performing on a project about semi-trailers. I've got an example made before but when I tried the same thing, the mesh did not be the same as the example I have.
      I gave the joint connections but for example, the pistons do not have any mesh but my setup has the mesh on the pistons.
      How can I make an analysis without mesh on the pistons? (or joints.)
      Can somebody tell me how can I do the same process? Thanks in advance.
      You can find the attachments about my question. I hope it'll clarify my question.
    • Ashish Khemka
      Hi Hakan,
      The parts on which you specified mesh are they rigid? What type of mesh did you specify, can you please share a snpshot? Also, can you try the following - right click on mesh -> Clear Generated Data and try remesh. Is the mesh in tree outline showing a green tick mark - indicating that meshing is completed?
      Ashish Khemka
    • hakan
      Hi Ashish,
      here is the mesh details on the example project. (same values as my project.) when I select "clear data and remesh" the program shows a yellow tick and doesn't return to green until the piston was meshed again.
      regards,
      hakan.
