We have an exciting announcement about badges coming in May 2025. Until then, we will temporarily stop issuing new badges for course completions and certifications. However, all completions will be recorded and fulfilled after May 2025.
Topics related to Mechanical Enterprise, Motion, Additive Print and more.
about modal analysis results..
    • byungchun
      hello
      I am doing some modal analysis for simple beam
      11 beams in a row and it has same material and stiffness.
      total 22 modes for 1st mode(x,z dir)
      but only 12 modes for 2nd mode
      I do not understand why it has only 12 mode it should be 22 modes for 2nd mode
      top and bottom are fixed all
      could you explain this?
      here is my model and results
       *** FREQUENCIES FROM BLOCK LANCZOS ITERATION ***
        MODE    FREQUENCY (HERTZ)
          1     2.202637444537
          2     2.202637444537
          3     2.202637444537
          4     2.202637444537
          5     2.202637444537
          6     2.202637444537
          7     2.202637444537
          8     2.202637444537
          9     2.202637444538
         10     2.202637444538
         11     2.202637444538
         12     2.202637444538
         13     2.202637444538
         14     2.202637444538
         15     2.202637444538
         16     2.202637444538
         17     2.202637444538
         18     2.202637444538
         19     2.202637444538
         20     2.202637444538
         21     2.202637444538
         22     2.202637444538
         23     4.962273009864
         24     4.962273009864
         25     4.962273009864
         26     4.962273009864
         27     4.962273009864
         28     4.962273009864
         29     4.962273009864
         30     4.962273009864
         31     4.962273009864
         32     4.962273009864
         33     4.962273009864
         34     4.962273009865
         35     11.90362864830
         36     11.90362864830
         37     11.90362864830
         38     11.90362864830
         39     11.90362864830
         40     11.90362864830
         41     11.90362864830
         42     11.90362864830
         43     11.90362864830
         44     11.90362864830
         45     11.90362864830
         46     11.90362864830
         47     11.90362864830
         48     11.90362864830
         49     11.90362864830
         50     11.90362864830
         51     11.90362864830
         52     11.90362864830
    • jj77
      One possibility is that The first two are similar modes, with same freq. but vibration in different planes. (say pipe will have the first 2 bending modes with same freq. in two different planes due to symmetry). In fact though the first 11 are one mode shape, and the others nr. 12-22 are for another mode shape in a different plane with the same freq.
      3rd mode (nr. 23 - 34) which is at 4.96 Hz for all beams does not have such a thing hence you get 11 x 4.96 Hz.
    • byungchun
      Thank you for response ^^
      I don't understand fully, I may dont have enough knowledge
      but they are not connected just single beam
      so they have to have their individual mode
    • jj77
      Ok - let's do a simple example.
      A beam with a circular cross section (so the cross section has a symmetry), will have the two first bending modes with the same frequency but with a predominant motion of the mode shapes along two different perp. axis (say e.g., z and y). Thus we expect 2 equal frequencies (similar mode shapes also) for 1 beam, but with different main motion (different dir.). If we have two beams we expect 4. Below is an example with two circular beams that are fixed, and as we said they have 4 modes with same frequency (~86 Hz) - this mode shapes are all first bending modes for the two beams - so 2 for 1 beam (but in different planes) and two for the other beam.
      The highlighted modes at ~ 780 Hz is a torsional mode and of course one mode for each beam (thus two freq. and two modes total, one for each beam). The second highlighted one is a longitudinal mode and again since they are not bending in different planes we get 2 in total just as for the torsional one.
      I can not explain this better - so you need to look at the mode shapes of your model and see what they are.
    • byungchun
      thanks for giving me informative info.
Viewing 4 reply threads
  • The topic ‘about modal analysis results..’ is closed to new replies.
