About retaining data in Parameter design
    • Nguyen Van Toan
      Hello everyone,
      When I used parameter set to obtain series of results. I checked the option to retain data (I think this will save all case datas). However when I saved my Workbench then opened, I set another case as current case and click "Result cell" to see detail result, there is no result and I need to update all again.
    • 1shan
      You need to update the design point before you can view the results. Have you done this? A green tick should appear once its updated.
      Regards Ishan.
    • Nguyen Van Toan
      Thank you Yes I have updated all, saved and set another case as current.
