June 20, 2023 at 4:45 am
June 20, 2023 at 5:43 pm
Guilin Sun
Ansys EmployeeThis indicates that either the min edge length is too small, the simulation has long and thin layer, has curved surface on a flat surface, or locally strong electric fields, or locally strong doping so to need fine mesh. You can also increase the iteration limits, minimize the triangle quality, minimize sensitivity, choose "disable interface mesh refinement". Anyway you need to relax the mesh refinement.
- Questions about the calculation of the cross-polarization conversion efficiency of metasurface
- Error on Lumerical device
- Lumerical – error message when trying to open from Linux terminal
7658
4476
2957
1433
1322
